Original Date: May 2003
Updated: October 2010
Flip your 3D cells on the fly!
To flip, or mirror 3D cells during placement, simply toggle the Mirror option.
If this option is not avialable on your version, try this tip from from Phil Frank, CAD Manager at Northeastern Log Homes. Locate and open Shortcut.txt and add the following keyins:
accudraw rotate x;accudraw rotate x
accudraw rotate y;accudraw rotate y
AskInga Tip #283
