Adjust the holes inside a group hole
AskInga logo
Original Tip Date: May 2003
Updated:  June 2010
Adjust holes and solids inside group hole
To adjust the shape of the solid or the holes in a group hole element, use the Element Selection tool, select the element and drag the handles to a new location!
AskInga Tips #280
