Original Tip Date: Apr 11, 2005
| Attach multiple models fast and easy | |
| To attach multiple models from one design file to another do this: Start a second instance of MicroStation and open the multi-model file you want to attach. Go to the Models dialog. Drag and drop the desired models into the Reference dialog of the active file. | |
communities.bentley.com/.../5224.Tip524.mp4 | |
AskInga Tip #524
