Original Tip Date: July 2001
Updated: November 2010
| Change text size based on the active scale | |
Phil Chouinard shares this tip: For example, if the active text size is 10, and the active scale is 2, then this keyin mdl load calculat;tx=*{tcb->xactscle} will result in a text size of 20. These keyins work fine in all versions of MicroStation including V8i.
AskInga Tip #118
