Original Tip Date: March 2007
Updated: November 2010
| Edit text in cells | |
| To edit text in cells using MicroStation V8 2004 Edition, ensure that your Text Editor style is set to Word Processor via Workspace > Preferences > Text. In MicroStation V8 XM Edition, you can edit text in cells using either the Word Processor, Dialog box or the WYSIWYG interface. | |
And finally, in MicroStation V8i, just double-click the text with the Element Selection tool. This automatically activates the Edit Text tool. It can't get any easier than that!
AskInga Tip #704
