Element Selection
Related Links:
Measure selected areas dynamically
VBA to select by fill colour
Fit selected elements to view
Use Clipboard Operations To Salvage Pre-Edited Graphics
Set The Default Snap Mode As A User Preference
Use The Nearest Snap To Locate Key Points On Text
Alternate Text Editing Handles In XM
Copy Selection Sets With The CTRL Key
Customize Quick Info Dialog
Unlock Angle Preservation When Manipulating Handles
Modify Handles For Multiple Elements
Zoom In On Selected Elements
Paste Elements At Same Graphical Location
Modifying Some But Not All Element Handles
Change Fence Mode From Status Bar
Selection Set Highlight Colour
