Original Tip Date: March 2004
Updated: December 2010
While trying to figure out what noise annoys an oyster the most, the following was posted: MicroStation V8 2004 Edition: To quickly move the input focus into the key-in window, stick this keyin on one of your function keys: dialog focus command | |
MicroStation XM / V8i : To move the input focus into the key-in window simply press the F9 function key. By default this executes the following keyin: inputmanager cmdbrowse . Of course, you can reassign this action to any of the 96 function key combinations. | |
AskInga Tip #407
