Edit text in cells already placed
AskInga logo
Original  Date: February 2001
Updated:  October 2010
Edit text in cells
To edit text in cells, without having to drop the cell first, use one of the following techniques:
MicroStation V7 - Select the cell, then choose the Analyze Element tool. In the resulting Element Information dialog, click on the Next button until you find the text, edit it and click Apply.
MicroStation V8i - Simply double-click the text in the cell to activate the Edit Text tool.
This functionality is not available with shared cells.
AskInga Tip #18
