Original Tip Date: Jan. 5, 2006
| Change various text rotations all at once | |
Ever get a file from someone and all the text is at different angles and you need a fast way to rotate them back to 0 degrees? Well, take a look at what you can do to quickly fix that! This workflow is available in MicroStation V8 XM Edition and newer. |
See also Change Text Attributes Tool - Overview |
AskInga Tip #577
