Original Tip Date: April 2005
| As you know, you can't delete the default model, however...you can trick MicroStation by doing this: Do a File > Save As... > Options > Filter > Models. Now select only the model that you'd like and save the new file. If only one model is selected, it will become the new master model. With thanks to Ian Kidd for sharing this on the v8.general discussion group. | |
communities.bentley.com/.../6278.Tip514New.mp4 | |
AskInga Tip #512
