Original Tip Date: Feb 16, 2001
Updated: August 2010
To change the colour that an element highlights when you snap to it, use this keyin:
In the V7 versions of MicroStation, you can use the following keyin to open a handy picklist that allows you to select the colour graphically: MDL LOAD HILITE 0 Note that this keyin does not work in any of the V8 versions.
AskInga Tip #48
