Original Tip Date: Jul 3, 2001
| You can change your working units by using a keyin. For example, to change the sub-units to 100 and positional units to 10, use the following keyin: MDL LOAD CALCULAT;calc tcb->subpermast=100;calc tcb->uorpersub=10 With thanks to Chuck Gummo for posting this to CCM! | |
AskInga Tip #106
