How to extract keyins for the tool settings in MicroStation V8i
Thanks, Gino, for providing this information!
To do this:
  1. Start any tool
  2. Open Utilities > Key-in and expand that vertically
  3. Type "set item toolsettings" but do not press "Enter"
  4. You should see a set of named variables for the active tool
  5. You can set (or unset) any variable listed by adding an "=" and then a 1 or 0 to toggle a tickbox, a value for a field, an item number in an optionlist, etc.
For example, in the above tool, you could use the following series of key-ins
place cell icon  (to start the tool)
set item toolsettings cellinteractiontype=1  (to set the interactive option)
set item toolsettings celltypeinteractivetoggle=1  (to enable the interactive toggle)
This can also be done in the Customize dialog when making custom tools by right clicking in an empty area and adding item settings:
