Original Tip Date: Jan. 20, 2006
| Quickly restore defaults with command line switch | |
To quickly restore the default settings of your installation of MicroStation V8 XM Edition or V8i, use the -restoredefaults command line switch. In doing so, the following folders will be cleaned:
AskInga Tip #617
