Define AccuDraw compass location (Set Origin)
Posting Date
: 2009-12-18
To position AccuDraws compass, you can either:
Do a tentative point and press the letter
O
Hold down the CTRL key while doing the tentative point.
Use this key-in on a function key:
buttonaction tentative;accudraw setorigin
