Original Tip Date: June 2003
Updated: January 2012
MicroStation V8 2004 Edition (08.05.xx.xx)
If you've checked Do Not Display Again in the DWG/DXF Units dialog, and now want the dialog back, locate and delete the following file: ...\Home\prefs\dwgdata\dwgsettings.rsc
MicroStation V8 XM Edition and MicroStation V8i
To restore the dilaog, select the file from the MicroStation Manager, and choose Options. From the DWG Open Options dialog, choose Advanced > Display Units Alert and turn on Unspecified Design Center Units.
AskInga Tip #291
