Posted: January 2012
With thanks to Jan Slegr for sharing this on the discussion groups.
Starting in MicroStation V8i SS3, you can change which page is displayed for multi-page PDF references. Simply right-click the file entry in the Raster Manager and choose Change Page from the pop-up menu.
