Original Tip Date: May 28, 2007
| Fit selected elements to view | |
| In MicroStation V8 XM Edition SELECT Update #1 you can use the enhancements made to the Element Info dialog to fit selected elements to the view. Just set the Browse Mode to Model, located on of the selected elements, issue a right click and select Fit To View from the pop-up menu. Since you must locate at least one highlighted element from a potentially huge element list, this workflow is better suited to files with fewer elements. Related Tip: Zoom In On Selected Elements | |
communities.bentley.com/.../0724.714.mp4 | |
AskInga Tip #714
