Original Tip Date: Nov. 5, 2003
| Delete unused levels when remapping | |
| Bentley's Dan Abney offered the following titbid on the v8.general newsgroup: The configuration variable MS_V7TOV8_DELETE_UNUSED_LEVELS also controls the deleting of unused levels when remapping. Set this varialbe to 0 to prevent unused levels from remaining when remapping V7 data with a CSV file. | |
AskInga Tip #331
