Original Tip Date: Jun 14, 2002
| Prevent Editing of the Printer Driver Configuration File | |
MicroStation 8.0 and later - Need to lock out your users from editing the printer driver configuration file? Can do with this configuration variable: Note, this is a lockable variable.
AskInga Tip #208
