MicroStation V8i - Element Selection (Input focus anywhere.) - Enter a data point anywhere in the view, but not on an element. - Key in choose none (better yet - put it on a function key.)
(Input focus in the tool settings window.) - Press the ; - Click the Clear button - Key in choose none
MicroStation V8 - Element Selection (Input focus anywhere.) - Enter a data point anywhere in the view, but not on an element. - Key in choose none
MicroStation V8 - PowerSelector (Input focus in the tool settings window.) - Press the Spacebar - Press the ' - Press the G - Click the Clear button in the tool settings window - Key in choose none
MicroStation V8 - PowerSelector (Input focus elsewhere such as keyin window or AccuDraw.) - CTRL + Click in the background of the view. - Key in choose none
MicroStation XM - Element Selection (Input focus at home.) - Enter a data point anywhere in the view but not on an element. - Press ; - Click the Clear button in the tool settings window. - Key in choose none.
MicroStation XM - Element Selection (Input focus elsewhere, such as AccuDraw.) - Enter a data point anywhere in the view but not on an element. - Key in choose none - Go home with ESC and use on of the methods noted above. ie: ESC+;
Note: The choose none keyin will work regardless of where the input focus is. As a result, some users prefer to put this keyin on a handy function key.
With thanks to Vince Rouse, Phil Chouinard, Michael Hall, Kirk Dunlap and Mark Sutheard for posting these suggestions to the discussion groups.
