Original Tip Date: May 29, 2007
| License Usage definition | |
Bentley's Tom Anderson writes: For pooled applications, SELECT Server tracks usage by machine and reports usage based on 1-hour intervals. Iterative sessions (any version) of the same application (i.e., MicroStation) on the same machine in the same calendar hour do not result in more than one usage, when compiled by SELECT Server. | |
AskInga Tip #715
