Original Tip Date: May 10, 2004
| Auto-Open a file to a specific model | |
| With thanks to Owen's Dad for this tip: MicroStation V8 2004 Edition has a new command switch that specifies the model to open. -Mmodel_name Therefor to open MyFile.dgn and pop directly into a model called MyModel, the command line would look like the following: | |
AskInga Tip #435
