Original Tip Date: Spring 2005
| Controlling text order when pasting into another application | |
When you copy/paste text from MicroStation into another application such as Excel, Word or even Notepad, the text will be pasted in the same order it was drawn in the design file. If this isn't correct, you have to re-order your text using this workflow: UPDATE: This does not work in MicroStation V8i. | |
AskInga Tip #517
