Original Tip Date: April 2005
Updated: November 2014
| Determine attached references without starting MicroStation | |
You'll love this tip contributed by Rudi Wells! This tip uses the -wa command line switch which specifies an MDL application to start when MicroStation is initialized. In this case, the MDL is ref which is delivered in the .../mdlsys/asneeded/ folder. Update: Testing on MicroStation V8i SELECTseries 3 indicates that the numerical options have been removed, but listing references still works -- see this forum post for more information and details regarding this.
communities.bentley.com/.../8105.Untitled.mp4 | |
AskInga Tip #519
