Original Tip Date: October 2004
Updated: November 2011 - Tested and confirmed to work in MicroStation V8i SS2
| Zoom to selected elements | |
This keyin script was posted to v8.general by Truels Wissneth and allows you to zoom in on elements that are in a selection set. communities.bentley.com/.../0068.462.mp4 Tip: Alternatively, the switching on and off of the sheet boundary could be integrated to the key-in, so you do not need to care for the switching of the sheet boundary: sheet boundary off;set displayset on;selview 1;displayset set selection;fit all;point ab;displayset clear;update view extended;sheet boundary on
AskInga Tip #462
