Calculating the quadratic transfer function
Q: How can I calculate the quadratic transfer function of a vessel in MOSES?
REV 6.01
A: As I understand it, a quadratic transfer function is used to evaluate second order effects on a floating body exposed to waves. These second order effects are really slowly varying wave drift. You can view wave drift data by using the v_mdrift command. If you are expecting to take wave drift output from MOSES, and use this as input to another program, you will likely have to perform some kind of conversion for units or format. MOSES was designed to solve all aspects of floating body problems, not to directly output quadratic transfer functions.
