Q: I only own MOSES, commonly referred to as MOSES Standard, how can I keep the program from switching to MOSES Advanced or MOSES Enterprise?
A: The default license in the MOSES Applications and the MOSES Solver must be set to “MOSES”. Note that the license setting for the solver in the .moses.ini file is independent of all other MOSES applications. Please take care to verify that the default has been set for the Applications and the Solver windows. The following link is a short movie showing the steps to set the default license in the MOSES Solver window.
http://communities.bentley.com/products/offshore/m/mediagallery/272451
