Soil liquefaction may occur when offshore foundations are subjected to seismic loading. The following equations are used to modify the P-Y and T-Z curves to simulate the effects of soil liquefaction.
The soil behavior is first classified using the soil behavior index:
Q and F are the normalized tip and sleeve friction ratios:
Where is the sleeve friction,
is the cone tip resistance,
is the overburden pressure,
is the effective overburden pressure,
is the atmospheric pressure, and
is the soil type exponent.
The soil type exponent varies between 0.5 in sands and 1.0 in clays. In SACS, the following values are used:
If the soil type is not specified, SACS will determine based upon the relationship between
and
The normalized dimensionless core penetration test can then be calculated:
Where is the overburden stress concentration factor:
The clean sand normalized core penetration resistance is then calculated;
Where is the clean sand normalization factor:
They cyclic resistance ratio, , can then be calculated:
where
is the user-defined vertical shift of the CRR curve and
is the user-defined horizontal shift of the CRR curve.
The cyclic stress ratio can be calculated as:
where
is the peak ground acceleration,
is the acceleration of gravity and
is the stress reduction factor calculated as:
The factor of safety can then be calculated:
Where is the magnitude scaling factor, expressed as:
Where is the earthquake magnitude.
If the factor of safety is less than 1, then soil liquefaction occurs in the soil layer and the following modifications are applied to the p-y, t-z, and q-z curves.
The corrected standard penetration resistance is calculated using the following equation:
And the soil liquefaction reduction factor is then determined using the Average Brandenburg curve:
may be modified with the liquefaction multiplier factor
The p-y, t-z, and q-z curves are then modified by the factor:
First calculate with n = 1.
If then soil type is considered to be CLAY and there is no liquefaction.
If then recalculate
and
If soil type is SAND. If
soil type is SILT then recalculate
and
