SACS Fatigue Solutions
This contains SACS wikis related to the SACS Fatigue program.
  1. Selection of "free corrosion" DNV curves
    2. SCF Method for Inline connection (DNV Options)
    3. SCF Method for Inline connection using ISO
    4. *** ERROR - LOAD CASE X HAS PERIODS NOT IN DESCENDING ORDER
    5. Fatigue Time Period vs Fraction of Design Life
    6. Spectral fatigue Tow and Hull deflection
    7. Speed up Fatigue Analysis
    8. Weibull Distribution - K & A Parameters
    9. Combining Fatigue Extraction Results
    10. Combining Multiple Fatigue Analysis - SACS Damage files (ftgdmo.)
    11. Defining Ring with CONRST line
    12. Eccentricity or fabrication misalignment and Warning Using DNV-RP-C203 "DN5"
    13. Fatigue Below Mudline
    14. Grout in Pile Fatigue
    15. Inspection points for SCF calculation
    16. Joint Flexibility and Behavior in Transfer Functions
    17. Relationship between "Stress-DA" on the response spectrum plots vs. the RMS stress in the Fatigue Stress and Damage report
    18. Scatter Diagram and Frequency of occurrences in fatigue
    19. SCF for a specific Joint connection?
    20. Transfer function in wave response vs Transfer function in Fatigue
    21. Use of the command MEMSCF and GRPSCF
    22. Fatigue results Error Load case number match
    23. Yoke Plate to jacket SCF Calculations
    24. Influence Function in SCF calc
    25. Transfer Function for Harris Spectrum
    26. FTLOAD Data
    27. Print connection transfer functions and response spectrum output
    28. SCF Calculation using DN2 and DN3 option in SACS
    29. Multiple SN Curve input in SACS Fatigue
    30. SCF option for Weld Root in SACS Fatigue
    31. How to set up a non-tubular SCF extraction using Joint Mesher tool?
    32. How to remove "Transient Duration" out from fatigue calculation
    33. Fatigue Load Conditions Settings
    34. User-Defined SCF
    35. JONSWAP Spectrum Parameters
    36. Center of Damage utility report
    37. Center of Damage utility
    38. Load Limitation in Fatigue Analysis
    39. Inline SCF Calculation when "ISO" is selected in FTOPT2 (Columns 51–53)
    40. Error: "FATIGUE LOAD CASE XX HAS 0 VALUES IN TRANSFER FUNCTION
    41. Joint Selection Using EXTRACT Not Reflected in Listing Output
    42. Response Functions Shown for Only One Fatigue Case in Listing file
