*** ERROR - LOAD CASE X HAS PERIODS NOT IN DESCENDING ORDER
Problem:
During post processing on spectral fatigue, I found below error:
What does this error mean?
Fatigue expects the wave periods used to define the transfer functions and wave spectra in descending order (increasing frequency). Check your input to ensure that your input is correct.
