Defining Ship Indentation Curve for Ship Impact Analysis
 Product(s):SACS Connect Edition - Collapse
 Version(s):All
 Area: Offshore Structural Analysis
 Original Author:Rafael Lara
In SACS Collapse program user is able to consider Ship Indentation Curves to be used during energy absorption calculations. The Ship Indentation Curve is set in the columns 27-30 of the IMPACT card.
Five pre defined curves are available:
User may also input a user defined curve by using the SHPIND card. In this case the same name used for the Ship Indentation Curve must be input in the columns 27-30 of the IMPACT line.
Figure below shows an example of an input for a user defined ship indentation curve:
