When attempting to open SACS Executive for SACS 13.2, you may get the following errors:
These are errors are most likely occurring because SACS was installed by another user on the machine and the registry keys have not been initialized for the current user. This post will address how to migrate the registry keys to the current user.
Download the attached text file, SACSRegistryEntries.txt, this file contains the default registry key values when installing SACS.
SACSRegistryEntries.txtChange the file extension to .reg, so that the file is associated as a registry key file. Your file should now look like this:
You should get a notification that the registry values have been applied:
