A Swagelok fitting is a type of high-integrity tube fitting commonly used to connect metal tubing in instrumentation, process, hydraulic, pneumatic, and analytical systems. When people say “Swagelok fitting,” they usually mean the company’s two-ferrule compression tube fitting. See Web site here.
How it works
A typical fitting has four key parts:
- Fitting body: the tubing slides into this.
- Front ferrule: forms the primary seal against the tubing and fitting body.
- Back ferrule: grips the tube and helps hold it securely.
- Nut: tightening the nut drives the ferrules into their working positions.
Imaged below:
Modeling procedure:
Swagelok fittings come in many shapes and configuration however this modeling approach will focus on just a simple Threaded by Tub connector. All other configurations can be derived using likewise assumptions.
- Suggest modelling this as a single component; recommend not modeling 4 individual components.
- End connections:
- Threaded:
- Piping: Modeled using the correct Pipe Properties for the threaded pipe / connector
- Threaded connection: The actual threaded connection should be handled by inserting an appropriate "Joint Type/User SIF"
- Tubing
- Piping: Modeled using the correct Pipe Properties for the tubing pipe / connector
- SwageLok connection: The actual SwageLok connection should be handled by inserting an appropriate "Joint Type/User SIF". contact the manufacture for appropriate SIF values or consider using a Socket connection.
- Body
- consider using a Rigid pipe property.
Modeling in AutoPIPE:
The SwageLok component can be any component in AutoPIPE that has 2 end points, ex. valve, reducer, etc..
- Insert Pipe with PipeID for Threaded pipe A00 - A01.
- Insert Reducer, A01 - A02
- Insert Pipe with PipeID for tubing pipe, A02 - A03
- Insert User SIF at A01 for threaded connection.
- Insert user SIF at A02 for tubing connection.
- Consider adding rigid properties to Reducer, consider both thermal and weight options.
