Error Code 746 - FATIGUE (Weld WX): Parameter (Kcss) cannot be determined (Table 3-D.2), chemical pr
Problem:
When performing Strength Calculations in AutoPIPE Vessel, the following error message appears:
Errors:
Error Code 746 - FATIGUE (Weld WX): Parameter (Kcss) cannot be determined (Table 3-D.2), chemical properties of the material are missing or incomplete, % carbon is required for parameter determination.
How to fix it?
Answer:
The Kcss parameter is used in the cyclic stress-strain curve model. Its value depends on the material and its chemical composition, including the material’s carbon content percentage.
For materials such as SA-240 Grade 316L, the carbon content may not be available in the AutoPIPE Vessel material database. Consequently, AutoPIPE Vessel cannot determine the applicable Kcss value from ASME Section VIII, Division 2, Table 3-D.2, and Error Code 746 is displayed.
Workaround:
Enter the missing carbon content in the material’s chemical composition using the Material Editor.
Note: Use the carbon content specified in the applicable material standard, material certificate, or approved project material data. Do not enter an assumed value.
Follow these steps:
    1. Open Material Properties of affected component by selecting Edit Material.
    2. Navigate to the Chemical Composition section. Confirm that the carbon content percentage is missing for the affected material.
    3. Right-click a column within the Chemical Composition table and select the option to insert a new column.
    4. Add a column for the carbon content percentage (%C). Enter the appropriate carbon content value and save the material file.
    5. Updating the material through the Material Editor applies the change wherever that material is used in the model.
    6. Run the analysis and you will not face the above error message.
After the carbon content is entered, AutoPIPE Vessel can determine the applicable Kcss value, and Error Code 746 should no longer appear for the affected welds.
Bentley AutoPIPE Vessel
Support Solutions and FAQ's
Error Messages
Warning Messages
Calculations
