Product(s): |
AutoPIPE CONNECT Edition 47.00.02.51 |
Version(s): |
47.00.02.51 |
Product Area(s): |
Reports |
Environment(s): |
AutoPIPE CONNECT Edition reporting for heat exchanger stress review |
Original Author: |
Mike Dattilio |
This article documents the case context for a heat exchanger model in which some seismic load cases continued to report excessive stresses even after increasing the thicknesses of items 25.02, 31.05, and the tubesheets. It exists to capture what was reported, what constraints were stated, and the current support status from the case record.
AutoPIPE users, support engineers, and reviewers who need background on reported high seismic stresses in a heat exchanger model.
The customer reported a heat exchanger model where stresses in some seismic cases remained too high. According to the case description, increasing the thicknesses of the shell and tubesheets did not reduce the stresses enough. The tubesheet thickness was constrained to no more than 40 mm because of the expensive cost of material. .
27 Tubesheet Loading conditions 4 [corroded normal condition]: longitudinal membrane stress in the tubes exceeded
998 LOCAL LOADS (xxx): beyond curve boundaries (WRC 537 cannot be applied).
475 FLANGE xxx : the location (or width) of the gasket is incorrect
Warnings
126 CHECKING ONLY (NO DESIGN): check warning message in calculation note
312 NOZZLE xxx: the external projection may not be sufficient (minimum=354.871 mm).
360 FLANGE xxx: the required space under the bolt is not available ( required=29 mm ; actual=24 mm ) (see: files boltISO.xlsx and/or boltUN.xlsx).
365 FLANGE xxx: the required space above the bolt is not available ( required=29 mm ; actual=25 mm ) (see: files boltISO.xlsx and/or boltUN.xlsx).
668 MATERIAL P355NH (EN10222-4): thickness 80 mm > 70 mm, tests are required to check the mechanical properties.
Perform the following steps whenever trying to understand AutoPIPE Vessel's results
After updating all of the missing Exceptional Allowable Stress values, correcting any other identified model input issues, rerunning the Strength Calculations, and review the newly generated output report verified that the seismic overstress conditions have been resolved.
In this reported heat exchanger case, increasing shell and tubesheet thicknesses alone did not resolve the excessive seismic stresses because the primary issue was related to incomplete material property data used in the exceptional load condition calculations. A systematic review of model warnings, errors, material assignments, and allowable stress definitions revealed that missing Exceptional Allowable Stress values caused seismic load cases to report overstress conditions with zero allowable stress limits. Once the missing values were defined and the model recalculated, the seismic overstress errors were resolved. This case highlights the importance of reviewing all warnings, errors, material properties, and load-condition-specific inputs before running Strength Calculations.
Shell and Tube Heat Exchangers
