| Version | PLAXIS 2D all supported versions PLAXIS 3D all supported versions |
| Date created | 13 October 2026 |
| Date modified | 13 October 2026 |
| Keywords | PLAXIS, staged construction, phase comparison, activation status, compare, GUI |
Identifying changes between staged construction phases can be challenging, particularly in models with many phases and construction activities.
The videos below demonstrate a practical workflow for comparing a reference phase with a target phase and identifying differences in the activation status of model objects in PLAXIS 2D and PLAXIS 3D.
For more information, check the details in the article "Quickly Identifying Staged Construction Configuration Changes in PLAXIS" and the relevant "Visual Examples".
