Product(s): |
AutoPIPE CONNECT Edition 47.00.02.51 |
Version(s): |
47.00.02.51 |
Product Area(s): |
Analysis / Calculations |
Environment(s): |
AutoPIPE CONNECT Edition desktop application, heat exchanger bundle analysis/calculation workflow |
Original Author: |
Mike Dattilio |
The customer reported in an exchanger model, changing the baffle cut from 22% to 20.1% caused the bundle to become unevenly split from the axis. The customer also reported that, regardless of the cut value, "the tubes do not fill completely the space.
No application error dialog, error code, or log signal was documented in the case notes. Exact UI error text not specified in the case.
Initial heat exchanger and layout of Baffle plates:
In the image above, what key observation should be made about nozzle N01, N02, N03, and N04? (Hint location of nozzles relative to the tubesheet)
Nozzles N01 - N02 and N03 - N04, were found to be designated incorrectly.
Question: What exactly is the function of baffle plates in a heat exchanger?
Answer: Baffles force the shell-side fluid to flow across the tubes in a zig-zag pattern instead of taking the shortest path through the shell. The baffle plates are evenly distributed between the Shell side Inlet / Outlet nozzles.
Question: What type of nozzle connections should be outside of the tubesheets and what type of nozzle connections should be between the tubesheets?
Answer: Correct, Tube Inlet / outlet nozzles are outside of the tubesheets, while Shell inlet / outlet nozzles should be between the tubesheets, as imaged below:
Therefore, simple resolution, update Nozzles N01 and N02 to be Tube side nozzles, while N03 and N04 are updated to become Shell side nozzles.
Now when reviewing the update baffle plate layout, the plates are evenly distributed between the Shell side Inlet / Outlet nozzles which are also inside of the tubesheets, making the universe correct once more, as shown below:
Shell and Tube Heat Exchangers
