Answer:
When reviewing AutoPIPE's Stress Summary Fatigue report notice the Cycles Actual and Allowed columns may have something similar that found in the screen shot below:
For ASME fatigue evaluation, the allowable cycles are obtained from the fatigue curve using the calculated alternating stress intensity (S-ALT).
When the calculated alternating stress is:
- Below the fatigue threshold/endurance limit used by the code implementation, or
- In a region where the fatigue curve effectively predicts no fatigue damage,
Then the allowable number of cycles approaches infinity or "inf".
As a result:
Notice the Report shows:
- INCREMENTAL = 0.0000
- TOTAL = 0.0000
The Actual column represents operating cycles applied. Thus a practical interpretation of "15inf" would be:
15 operating cycles applied, while the
allowable cycles are infinite (or effectively unbounded),
The report formatting is somewhat confusing because AutoPIPE concatenates the actual cycle count and the infinite allowable cycle indication in the same area.
Note:
One reason why Allowed Cycles is calculated to Infinity is because the Pipe Property Environmental Factor equals 0.00 (see AutoPIPE help on this setting).
Changing the Pipe Property Environmental Factor to a non-zero value should calculate an actual Allowable Cycles value:
Example: Set value = 1.0
"Stress Summary" sub-report using Results> Output Report
