PLAXIS 2D 2026.1 Release Notes
New in PLAXIS 2D 2026.1
Release: October 2026
PLAXIS 2D 2026.1.0 (26.1.0.211) contains the following improvements and updates compared to PLAXIS 2D 2025.1:
New features
Cloud Interoperability: PLAXIS & GeoStudio - Tech Preview
Seequent Evo enables cloud-based interoperability between PLAXIS and GeoStudio, allowing teams to share 2D geometry with material name and colours. By reducing manual data recreation and improving consistency across geotechnical models, engineers can streamline workflows, enhance collaboration, and work more efficiently within a connected digital ecosystem.
This feature is released as a 'Tech Preview' under our Product Terms and requires access to Seequent Evo.
Cloud Interoperability: PLAXIS 2D & Leapfrog - Tech Preview
PLAXIS 2D and Leapfrog are now connected through Seequent Evo, enabling cross sections to be shared seamlessly between applications. This cloud-based workflow reduces manual data transfer, improves consistency between geological and geotechnical models, and helps teams collaborate more effectively using a common source of truth.
Other changes and improvements
Compatibility note: To ensure there is no data loss in the original project and properly converting modified project properties, when opening older projects, they will be converted and saved with a _converted suffix. Specifically when opening projects older than the 2025.1 version, due to major changes in the calculation input and results database, the projects require remeshing and recalculation.
Side-by-side installation with a previously released major version of PLAXIS is supported (e.g., PLAXIS 2025.1.x and PLAXIS 2024.3.x), enabling a smooth transition to the new version without impacting ongoing projects.
Be aware that earlier versions of PLAXIS will not be able to open files saved in PLAXIS 2D 2026.1.
Fixed issues
A large number of issues have been addressed, including:
Download links
You can update to the latest version using the CONNECTION Client or download the installer via Bentley System's Software downloads page.
