AutoPIPE Vessel estimates stress concentration factors Kn and Kb using the correlations provided in Annex B of WRC Bulletin 107, where the primary controlling parameter is the ratio of fillet radius to shell thickness (r/T)
Where:
As the fillet radius increases, the geometric transition becomes smoother and both Kn and Kb decrease. This reduces the stress concentration at the nozzle-shell junction.
Following values are used by AutoPIPE Vessel to estimate the local stress concentration effects associated with the attachment fillet radius.
