MCP Server
Back to Product Wiki
MCP Server
MCP (Model Context Protocol) is an open standard that lets AI assistants connect directly to external systems and data sources through a defined set of tools. An MCP server for iTwin IoT exposes the iTwin IoT platform as a set of callable actions an AI can use on a user's behalf.
In practice, this means an AI connected to the iTwin IoT MCP server can:
Query live and historical data
pull sensor readings, device status, alert states, and time-series observations from monitored assets (bridges, dams, buildings, construction sites, etc.)
Bulk actions
Update sensor names, group names, mass create standardized dashboards and more
Manage infrastructure configuration
create and update nodes, devices, sensors, and calculations that make up a digital twin's monitoring network
Set up and manage alerts
configure threshold, correlation, pattern, vibration, or status alerts that flag anomalies in sensor data
Run analytics and ML jobs
trigger regression, trend, classification, or anomaly-detection models against sensor data
Generate reports and visualizations
build dashboards, graphs, and scheduled reports summarizing asset health- Handle documents and files — upload, organize, and retrieve inspection reports, imagery, and other project files tied to monitored assets
Provide product guidance
it can read and feed iTwin IoT KnowledgeBase articles directly into the chat with references to our articles and images from those articles.
Instead of a person manually navigating the iTwin IoT web portal to check on a dam's tilt sensors or configure a new vibration alert, they can just ask the AI in natural language, and the MCP server translates that request into the correct API calls against the platform.
To see a complete list of the tools available to the AI Agent please navigate to https://itwiniotai-mcp.bentley.com/docs
You will have to authenticate via your Bentley IMS account to access this list.
Usage examples
Asset summaries
Bulk actions
Create and curate dashboards for your asset
List of supported AI Agents connectors
Claude
Github Copilot
Gemini Enterprise
OpenAI
Microsoft Copilot
