Category: Configuration
OBDPSConfigurationError
Error Message: Unable to run the OpenBuildings / ProStructures Connector. A configuration error was detected.
Issue:
There is a configuration error that prevents the connector from starting.
Cause:
The error is caused by an unexpected error in the contents of the workspace configuration file, and the Connector could not read it.
Please verify that your managed configuration is defined correctly.
