Effect of Water Flow on Freezing around a Pipe
Introduction
Groundwater flow can have a significant effect on ground freezing because heat flow via forced convection is often more effective at moving energy than conduction alone. Numerical analysis of the conduction-convection process requires a coupling of the heat and water transfer equations. This example discusses the methodology and material properties required for a heat transfer analysis involving groundwater flowing around a freeze pipe. The effect of pore-ice blockage on water and heat transfer is highlighted.
Downloads
▪ 📗 GeoStudio - TEMP/W - Effect of Water Flow on Freezing around a Pipe - Information [PDF]
▪ 💻 GeoStudio - TEMP/W - Effect of Water Flow on Freezing around a Pipe - Project [gsz]
See also
