Thermosyphon Laboratory Test
Introduction
Thermosyphons are routinely used in colder climates for the preservation of permafrost. The preservation of permanently frozen ground in-turn protects infrastructure such as pipelines, frozen core dams, buildings, and trafficable surfaces. The objective of this example is to demonstrate how to define a thermosyphon boundary condition in TEMP/W by simulating a laboratory experiment that can be developed to measure the overall heat conductance of a thermosyphon.
Downloads
▪ 📗 GeoStudio - TEMP/W - Thermosyphon Laboratory Test - Information [PDF]
▪ 💻 GeoStudio - TEMP/W - Thermosyphon Laboratory Test - Project [gsz]
See also
