Major features
- NVIDIA Iray Upgrade. Updated the integrated NVIDIA Iray rendering engine from version 2021.0.3 to 2025.0.12. Users can benefit from improved compatibility with newer NVIDIA GPUs and rendering improvements available through the Iray functionality exposed in SYNCHRO 4D Pro
- Added additional diagnostic information to help investigate and troubleshoot application responsiveness issues.
Bugs squashed
- Fixed an issue where importing Primavera P6 XML files exported from a P6 database could fail during the import process. This improvement allows supported P6 project data to be imported more reliably using the default import workflow.
- Fixed an issue that could cause SYNCHRO 4D Pro to crash when projects were repeatedly closed and reopened during the same application session.
- Security fixes.
Downloads
Click the links below to download the latest version or visit Software Downloads.
