STAAD.Pro 26.00.00.340
List of critical and high severity defects identified in STAAD.Pro V2026 build 26.00.00.340
Issue ID Title Severity 1st affected Build Fixed in Build
A-524650 Member section displacement results do not account for lateral releases on members  2 - High 20.07.04.12 Known Issue
A-1988266 Seismic self weight calculation for very short tapered I profiles  2 - High 21.00.02.30 26.00.01.491
A-2084603 AS4100 (1998/2020): Incorrect web slenderness limit for Tee profiles  1 - Critical 20.07.04.12 26.00.01.491
A-2094654 AISC 360-16/22: Incorrect default SNUG value for built-up members  1 - Critical 21.00.02.30 26.00.01.491
A-2106652 CSA S16-09/14: Limiting value of Factored Moment Resistance (Mr) as per Clause 13.6(a)(i)  1 - Critical 20.07.10.41 26.00.01.491
A-2009553 Wind Load assignment Combining RANGE and LIST methods  2 - High 20.07.04.12 26.00.01.491
A-2016637 AISC ASD: Incorrect Section Modulus used in design of multiple angle profiles  1 - Critical 20.07.08.22 26.00.01.491
A-2017394 Local deflection checks of models distant from the global origin  2 - High 20.07.04.12 26.00.01.491
A-2024531 Incorrect open-structure wind loading for angle profiles  1 - Critical 20.07.04.12 26.00.01.491
A-2092167 Incorrect processing of floor load within a reference load case  1 - Critical 20.07.08.20 26.00.01.491
A-2011909 EN1993-1-1-2005: Section classification check is skipped  2 - High 20.07.06.23 26.00.01.491
A-2125826 IS 1893 (Part 1) 2016: Incorrect static base shear used for comparison with response spectrum base shear  2 - High 21.03.00.146 26.00.01.491
A-2017710 Enclosed Zone Load with disconnected regions  2 - High 23.00.00.345 26.00.01.491
A-1996410 AS 4100-1998/2020: Reference Buckling Moment underestimated for UPT wide-flange profiles  2 - High 23.00.02.361 26.00.01.491
A-2083883 Connection Design Workflow: Error in re-designing connections  1 - Critical 24.00.00.577 26.00.01.491
A-1974613 IS 800 2007 LSD: Incorrect bending capacity of slender monosymmetric section  2 - High 25.00.00.539 26.00.01.491
A-2098565 EN 1993-1-1-2005: Torsion checks for closed hollow sections  2 - High 25.00.00.539 26.00.01.491
A-2112587 EN 1993-1-1-2005: Reduced effective section properties for Class 3 members  2 - High 25.00.01.424 26.00.01.491
A-2123763 AISC Direct Analysis: Ignore Axial Stiffness Reduction  1 - Critical 25.00.01.424 26.00.01.491
A-2128914 Response Spectrum Base Failure to Process UNIT Commands  1 - Critical 25.00.01.424 26.00.01.491
