This ReadMe summarizes the requirements, installation and licensing, documentation, and supported piping codes for AutoPIPE 2026, along with what's new and the error history for this and previous releases.
What is New & Changed in AutoPIPE®
AutoPIPE 2026 is a yearly release which gets updated by occasional minor releases for security, critical fixes, and improvements. The details of the releases are provided below:
Piping Codes
Added ASME NM.1 (2022) Thermoplastic Piping Systems, a new piping code in AutoPIPE for the design of thermoplastic pressure piping systems.
Added the 2024 edition of EN 13480-3 Metallic Industrial Piping. This edition introduces no changes affecting AutoPIPE design calculations compared to EN 13480 (2017 + 2021 addenda).
Enhanced EN 1591 Flange Design, including:
A new grid for performing operations on multiple flanges
Support for updating the material library via the Library Editor
Improved consistency and design checks
Added the 2022 edition of ASME B31.4 Pipeline Transportation Systems for Liquids and Slurries. Key updates:
ASME B31J is now solely required for flexibility and stress intensification factors
Revised calculation of allowable expansion stress for unrestrained pipelines
Added the 2022 edition of ASME B31.4 Chapter IX Offshore Liquid Pipeline Systems, which now requires ASME B31J exclusively for flexibility and stress intensification factors.
Added the 2022 edition of ASME B31.8 Gas Transmission & Distribution Piping Systems, with no changes affecting AutoPIPE design calculations compared to the 2020 edition.
Added the 2022 edition of ASME B31.8 Chapter VIII Offshore Gas Transmission, with no changes affecting AutoPIPE design calculations compared to the 2020 edition.
User Interface
Added option to disable flexibility factor calculations for ASME B31Jtees.
Increased maximum length of Pipe Identifier from 8 to 24 characters.
Introduced Bentley Copilot within AutoPIPE, the digital assistant service enabling natural language queries against product documentation.
Analysis
Implemented an alternative response spectrum seismic analysis approach, including:
Configurable spectra combination options
Configurable directional combination options
Independent specification of ZPA frequencies from the model’s modal cut-off frequency
Security Release Notes
No security updates for this release.
[ Technology Preview ]
Technology Previews provide users preliminary access to features currently in development and not QA certified and therefore not yet ready for production. These features are provided at no additional charge to promote awareness of a feature or technology to be deployed in a future release. Users are encouraged to provide feedback and suggestions. To learn more about Technology Previews, please create a Service Request (be sure to include "Technology Preview" in the Description field).
AutoPIPE® Requirements
More detailed installation information can be found in the AutoPIPE Quick Start Guide.
Product Version
Product
AutoPIPE
Version
26.00.00.306
Language
English
Japanese
Polish
Chinese (Simplified)
Included Applications Versions
PCF Translator
1.6.0.306
PDS Translator
6.0.0.32
ADL Pipe Translator
1.0.0.38
ME101 Translator
1.0.0.022
iTwin Analytical Synchronizer
23.01.22.21
iTwin Services Add-in
26.02.00.031
23.01.22.021
Installation Requirements
Access to the Internet required for product installation. The minimum system configuration for installation:
Operating System
Microsoft Windows 11 x64 Professional or higher
.NET Framework
4.8.1
When installing the product through the installer program, the required components will be installed automatically. The contents of the Desktop Prerequisite Pack include:
Microsoft® .NET Framework 4.8.1
Microsoft® VC++ 2015-2022 Redistributable (x64)
CONNECTION Client - 25.00.02.19
NOTE: AutoPIPE uses the following fonts on dialogs and in reports. These fonts are pre-installed with Microsoft Windows. If any of these font are missing, the text on dialogs and in reports may appear smaller/larger than usual. To install missing fonts, please repair or reinstall Microsoft Windows.
Arial
Calibri
Consolas
Courier New
Georgia
Microsoft Sans Serif
MS Sans Serif
Segoe UI
Times New Roman
Minimum Profile
The minimum recommended workstation profile for running AutoPIPE is:
Memory
8 GB recommended.
Hard Disk
4 GB free disk space (not including Restore Point space requirements).
Video Graphics Card
Any industry-standard video card which supports OpenGL 3D graphics.
ProjectWise
ProjectWise Server 25.00.01 with ProjectWise Explorer 26.00.00
ProjectWise Server 25.00.01 with ProjectWise Explorer 25.00.02
Note: ProjectWise Server and ProjectWise Explorer are only required if Bentley's ProjectWise is used to manage project documents.
OpenPlant Isometrics Manager
OpenPlant Isometrics Manager 2024 - 24.00.03.025
Note: Users can use OpenPlant Isometrics Manager (OPIM) to review Stress Isometrics created by AutoPIPE without an entitlement for OPIM, provided it is opened from within AutoPIPE. Direct use of OPIM without an entitlement will log usage and may lead to charges. Click here for more information.
Word processing, spread sheets, and access database
To complete the licensing process, you must have the appropriate roles assigned by your Site Administrator. If you have not been assigned these roles, you will need to contact your Site Administrator.
If you are experiencing problems logging into your Bentley account, please contact Bentley's Licensing department at 1-800-BENTLEY (1-800-236-8539). Outside the United States +1 610-458-5000.
Network Considerations - Network drives are only supported for data files.
AutoPIPE software must be installed on a local client workstation.
AutoPIPE data files must have full read/write access to be opened and edited.
Documentation
Program Help
Detailed feature information may be accessed directly from within AutoPIPE by selecting the Help command, or by pressing the Help button from any of the application dialogs. Be sure to explore the program Help for answers to your questions. A set of supplemental How To, Tutorial, and Reference Information documents in PDF format are provided in the Supplemental Documentation folder (Bentley AutoPIPE > Supplemental Information) of the main Program Help.
Documentation is also available online on Bentley Software Documentation. Bentley's Documentation Assistant enables the user to query program documentation in natural language and get responses from within the selected documentation.
AutoPIPE's Help menu includes tutorials in PDF format, viewable in any standard PDF reader.
Piping Codes
This sections contains the list of piping codes, code editions supported and AutoPIPE license edition (Standard, Advanced or Nuclear) for which these items are supported.
Standard Edition Piping Codes
Piping Code
Description
B31.1 Power
Power Piping
B31.3 Process Piping
Process Piping
B31.4 Liquid Trans.
Liquid Transportation Systems for Hydrocarbons, Liquid Petroleum Gas, Anhydrous Ammonia and Alcohols
B31.8 Gas Trans. & Dist.
Gas Transmission and Distribution Piping Systems
EN 13480
European Piping Code for Metallic Industrial Piping
General
General Piping Code
ASME B31J
Stress intensification factors, flexibility factors, and sustained stress factors used in B31 piping analysis
Extra Codes Available in AutoPIPE Advanced Edition
AutoPIPE Advanced includes all codes available in AutoPIPE Standard, as well as the following codes.
Piping Code
Description
CSA-Z662
Canadian Standards Association, Oil and Gas Pipeline System
CSA-Z662 Offshore
Canadian Standards Association, Offshore Steel Pipelines
BS 806
Design and Construction of Ferrous Piping Installations for and in Connection with Land Boilers
BS 7159
Design and Construction of Glass Reinforced Plastics (GRP) Piping Systems for Individual Plants or Sites
SPC-2
Swedish Piping Code, Method 2
TBK5-6
General Rules for Piping, The Norwegian Pressure Vessel Committee
STOOMWEZEN
Dutch Piping Rule D1101 of the Rules for Pressure Vessels
DNV Offshore
Det Norske Veritas, Rules for Submarine Pipelines
MITI 501 3-1980
MITI 501 Class III Piping Code
KHK
KHK E 012 Piping Code, Seismic Level 1 or 2 (Seismic Level 2 requires a KHK 2 Add-On license)
RCC-M
French Piping Code for Power Industry
SNCT
French Piping Code for Process Industry
SNIP Russian 2.05.06-85 Oil & Gas
Russian SNIP piping code for oil and gas
ISO 14692
Petroleum and Natural Gas Industries - Glass Reinforced Plastics (GRP) Piping
B31.4 Offshore
Offshore Liquid Piping Systems
B31.8 Offshore
B31.12 Hydrogen Industrial Piping
ASME B31.12 Hydrogen Pipelines (Section IP)
ASME B31.12 Hydrogen Pipelines (Section PL)
ASME NM-1
ASME Thermoplastic Piping Systems
ASME NM-2
ASME Fiber-Reinforced Thermosetting-Resin Piping Systems
Extra Codes Available in AutoPIPE Nuclear Edition
AutoPIPE Nuclear includes all codes available in AutoPIPE Standard and AutoPIPE Advanced, as well as the following codes.
Piping Code
Description
ASME NB Nuclear
Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection NB, Class 1 Components
ASME NC Nuclear
Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection NC, Class 2 Components
ASME ND Nuclear
Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection ND, Class 3 Components
ASME NCD Nuclear
Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection NCD, Class 2 and Class 3 Components
JSME PPC Nuclear
JSME S NC1: Rules on Design and Construction for Nuclear Power Plants, Class 2 Piping
Error History
The following outline identifies all major errors fixed in AutoPIPE 2025 (25.0.0) yearly release and occasional minor updates:
AutoPIPE 2026 (26.0.0)
Defect 1958211: ASME NC, ND, NCD: Program may not limit the coefficient 0.75*i to the minimum value for use in equation 11 for user-defined stress intensification factors
The sustained stress term coefficient in equation 11 of ASME NC, ND, and NCD piping codes is defined as 0.75*i, but no less than 1.0, where i is the stress intensification factor. AutoPIPE may not consider this minimum coefficient limit for user-defined stress intensification factors, resulting in incorrect stresses for user factors less than 1.333.
Defect 1990173: ASME B31.1 & B31.3 Libraries: Modulus of Elasticity may be incorrect for some code and standard materials
In the ASME B31.1 and B31.3 material libraries, the reference standard materials for some code materials refer to the incorrect steel categories when determining the Modulus of Elasticity. Moreover, the standard material NI (Nickel Steel) in the ASME B31.1 and B31.3 material libraries incorrectly refers to Nickel Alloys when determining the Modulus of Elasticity.
Defect 2021342: Seismic Thermal Load: Units for user-defined Temperature and Expansion are always treated as English units resulting in incorrect unit conversion
The Generate Seismic Thermal Load Case dialog can be used to assign Temperature and Expansion properties to a soil identifier using a thermal load case. User-defined Temperature and Expansion values can also be assigned by unchecking the Auto checkboxes. In case of user-defined values, the input units for these two fields are incorrectly always treated as English units regardless of the input units displayed on the dialog. This can lead to the user-defined values being processed using the incorrect units.
Defect 2041354: EN 13480 Material Libraries: A333-3 and A333-6 refer to the incorrect material groups when determining the Modulus of Elasticity
The nominal composition for A333-3 provided by ASME BPVC II-D is 3 1/2Ni, which is part of Material Group B in Table TM-1, but A333-3 incorrectly refers to the group Carbon steels with carbon content less than or equal to 0.3% when determining the Modulus of Elasticity. The nominal composition for A333-6 provided by ASME BPVC II-D is Carbon Steel, which corresponds to Carbon steels with carbon content less than or equal to 0.3% in Table TM-1, but A333-6 incorrectly refers to Material Group B when determining the Modulus of Elasticity.
Defect 2046014: ASME B31.1 & B31.3 Material Libraries: Thermal Expansion Coefficient and Density values may be incorrect for some code and standard materials
Materials A333-3 and A333-9, found in the AUTO1967.src and B311-73.src libraries, and NI (Nickel Steel), found in the B313-24.src library, may reference incorrect material categories when determining Thermal Expansion Coefficient values. Additionally, NI (Nickel Steel) in all ASME B31.1 and ASME B31.3 material libraries incorrectly references Nickel Alloys when determining the Density values.
Defect 1987197: B31.8 Material Libraries: Material Composition is incorrect for A333-3 and A333-9, and Young's Modulus and Density values for NI are incorrect
In the ASME B31.8 material libraries, the reference standard material for A333-3 and A333-9 incorrectly refers to low-carbon steel material data instead of nickel-steel material data when determining the Modulus of Elasticity. Moreover, the standard material NI (nickel-steel) incorrectly refers to Nickel alloys (UNS No. Alloys N02200, N02201, N06625) when determining the Modulus of Elasticity and Density. As a result, incorrect Modulus of Elasticity and Density values may be used during analysis. This defect impacts all ASME B31.8 material libraries from AUTOB318 through B318-20.
Defect 1967667: ASME B31.3 and B31.1 Libraries: Reference standard material for some carbon steel specifications incorrectly refer to low carbon instead of high carbon for Modulus of Elasticity
This defect is limited to High severity as the difference between incorrect and correct Modulus of elasticity and its impact on program results is ~ 1%. In the ASME, B31.3 and B31.1 material libraries, the reference standard material for some carbon steel specifications incorrectly refers to low-carbon material data instead of high-carbon material data when determining the Modulus of Elasticity. As a result, incorrect modulus values may be used during analysis for affected materials.
Defect 1990784: ISO 14692 (2017): Code allowable for non-thermal load combinations maybe incorrectly reported for points containing a flange
This defect only affects models using piping code ISO 14692 2017 edition in AutoPIPE version 12.6.5 through version 2025. Code allowable maybe incorrectly reported for points having a flange with Lifetime (hrs) greater than 175200 hours. When evaluating the A0 factor to determine the allowable stress, AutoPIPE incorrectly uses the Bolt/Nut Weight of flanges instead of the cold gradient for points that contain a flange. This is only valid for Gravity load combinations that do not contain a Thermal nor Pressure load case. If the Bolt/Nut weight is less than the cold gradient value entered in the corresponding Pipe Property, the allowable result maybe unconservative. Typically, cold gradient is on the order of 1e-3.
Defect 1983997: ASME NC, ND, NCD: Program may not limit the product 0.75*i to the minimum value for use in equation 11 for cross-type junction stress intensification factors
Applicable program versions are AutoPIPE 9.2.2 through AutoPIPE 2025. Impacted piping codes are ASME NC, ND and NCD 1983 through 2023 with Service Level A-D Stress Summaries evaluating Equation 11. Crosses are the only impacted components by this bug. This bug is limited to High severity since crosses are not code components. ASME NC, ND and NCD Equation 11's sustained moment term is multiplied by (0.75*i), which can be no less than 1.0 as per code mandate. However, AutoPIPE incorrectly allows (0.75*i) multiplier less than 1.0 for crosses having User-defined SIF less than 1.333. User-defined SIF for crosses can be specified through Tee dialog by setting Tee component as Cross and Type of tee as Other. This lower limit ignorance for Equation 11 SIF multiplier by AutoPIPE may lead to incorrect Equation 11 stress evaluation for crosses.
Copyright
TRADEMARK NOTICE
Bentley, the "B" logo, AutoPIPE, MicroStation, ProjectWise, SELECT, and MDL are either registered or unregistered trademarks or service marks of Bentley Systems, Incorporated, or one of its direct or indirect wholly-owned subsidiaries. Other brands and product names are trademarks of their respective owners.
Including software, file formats, and audiovisual displays; may only be used pursuant to applicable software license agreement; contains confidential and proprietary information of Bentley Systems, Incorporated and/or third parties which is protected by copyright and trade secret law and may not be provided or otherwise made available without proper authorization.
Complete copyright information can be found in the product by choosing Help > About.
For reference, a copy of the End User License Agreement named "EULA.pdf" is included in the product installation folder.
Corporate Headquarters
Bentley Systems, Incorporated 685 Stockton Drive Exton, PA 19341, United States 1-800-BENTLEY (1 800 236 8539) Outside the United States +1 610 458 5000
Bentley EMEA
Bentley Systems International Limited Charlemont Exchange 5th Floor, Charlemont Street Dublin 2, D02VN88, Ireland 1800 948 368 +353 1 436 4600
Bentley Asia
Bentley Systems (Beijing) Co., Ltd. Unit 1402-06, Tower 1 China Central Place Beijing 100025, China 400 842 7516 +86 10 5929 7000
