Incorrect Spread Calculations for Combination Inlet in Sag Using 'Curb Only' Option
Product(s):
StormCAD, CivilStorm, SewerGEMS, FlowMaster, OpenRoads Designer
Version(s):
26.00.00.514 and earlier (OpenFlows), 25.00.01.10 (OpenRoads)
Product Area(s):
Drainage and Utilities
Original Author:
Jesse Dringoli
Purpose
This article provides conceptual background and key information regarding the observed issue of incorrect spread calculations for combination inlets when using the "Curb Only" calculation option in OpenFlows StormCAD and related products. It aims to clarify why this issue occurs, its implications, and what users should be aware of when modeling such inlets.
Audience
This article is intended for drainage engineers, hydraulic modelers, and technical users of OpenFlows StormCAD, CivilStorm, SewerGEMS or OpenRoads Designer who are responsible for modeling and analyzing stormwater inlets, particularly those using VDOT standards or similar workflows.
The issue arises when modeling combination inlets (such as VDOT Standard DI-2) using the "Curb Only" option for the "Active Components for Combination Inlets In Sag" in the calculation options:
The expectation, based on hydraulic standards like the VDOT Drainage Manual, is that the "Curb Only" option should ignore the interception capacity of the grate and only account for the curb opening length. However, users have observed that, when using the "Curb Only" option, the spread is much less when compared to a DI-3 curb inlet, or a a DI-2 combination inlet with 100% clogging, when all other characteristics (inlet location, depression, gutter, and cross slopes) are identical. This discrepancy suggests that the software is not correctly ignoring the grate's capacity for combination inlets when "Curb Only" is selected. The issue has been present in multiple versions and may affect the sizing and performance evaluation of inlets in design workflows where the grate must be ignored, potentially leading to undersized infrastructure if not recognized.
Key Information
Workaround
In OpenRoads Designer, a workaround is to use the "Grate and Curb" calculation option and set the clogging factor to 100% for combination inlets where the grate should be ignored, or use a curb inlet type if compatible with project standards. This can be used in Prototypes for feature definitions, in OpenRoads Designer.  Note that using a curb inlet may not be an option for OpenRoads Designer due to the way prototypes and feature definitions work.
Additional Notes
  • Related documentation on inlet calculations and spread behavior can be found at: KB0014922 and KB0016743
  • Users are encouraged to communicate the workaround internally and update any standard seed/template files as needed until a software fix is available.
  • The issue has been acknowledged by Bentley technical support and escalated to development for future resolution (to be fixed in OpenFlows products first, and then picked up on in the subsequent OpenRoads release). Reference number 2081456. Update 2026-Oct-5: a fix is now planned for the next releases of OpenFlows and OpenRoads.
