Picklist Component Downloads
Please see our Component Downloads page for instructions on using the examples below and to explore additional component downloads.
This page contains download links for components that will add new Picklists to your configuration pack or project.
Item Description Example
Munsell Colors Adds a "Munsell Colors" picklist with opaque images.
Munsell Colors Transparent
Adds a "Munsell Colors Transparent" picklist with semi-transparent images.
(The transparent images can be used in a similar fashion to what is described in this article to overlay the colors on pattern-based graphics. You would need to create a custom Picklist header for entering the Munsell Color. And you will need to add a Graphics Bar in Template Studio that references the Munsell Color header. It is important to use the "FitToWidth" option for this Graphics Bar, or the colors might be distorted.)
